BL/3D touch with G33
Hey guys
a LONG shot - for a more accurate mesh - is there a way to use a 3Dtouch probe with G33 to get a more accurate map? I don't really want auto level just yet but want the mesh for better manual levelling.
G1 X100 Y100 Z20
z should be what you have set as z probe bed distance. Then just run
G33
and it will measure all points automatically. But as I said BLtouch has it's own requirements to distances and timings which you need to fulfill. If you can run a G30 successfully at X100 Y100 it should be no problem.
I don't have a clue. the 3Dtouch is connected to pin11 and is working and the sensor wires to Y Max. It's not measuring anything.
Why not use the 3dtouch on Z min and use it for Z homing and also bed levelling.
What type of printer do you have ?
What firmware is installed ?
There is no real tutorial. There are so many combinations that it is not possible to describe like a tutorial. Just test functions and see if it does what expected. Mainly motor assignment/direction/steps/end stops are the critical parts.
