G32 first 3 layers printing are at the same height
Hi there,
Need some help with this, i guess i'm doing something wrong but i dont know where to look.
what i do:
- first a G28
- Then G32 S2 using method 1 (the grid 4 points), bedleveling is going good nothing wrong here.
- trying to print, first layer is OK, then its staying at the same height, for 3 layers before i see a hardware z change.
first thing a thought was that the Z stepper was the blame, but by moving it manually i dont see missing steps.
im printing from repetier server.
what i saw that is that the printer settings in repetier server the height not being updated after a G32, u have to do it manually but cant immagine that this can cause any problems.
in the firmware i have G32 and G33 enabled, i only us G32.
maby somebody has the same thing or knows something what i didnt do.
what i do:
- first a G28
What can happen is that you start too close to bed and do not register z going up as nozzle still presses against bed. That prevents extrusion in the wanted amount and you normally hear extruder loosing some steps.
uhmm...... yeah, i guess doing late at night stuff is sometimes not a good thing.
i releveled everything using G30 to get z heights.
after that a g32 and saw that my height was off
zo z-probe height wasn't good, after adjusting it everything worked ok..
thanks for the quick response
