Z probe causing X to slam X min endstop
Any time I enter G32 to auto level bed my X axis slams in to the X min endstop which does not stop it, it will continue to grind for a couple moments then go on to probe the bed. How can I make this stop?
The endstop works any other time when I'm homing or any time the X flag hits it, just not when auto leveling with G32 command.
Also my z probe isnt very accurate. Some times auto bed level makes extruder hit bed, some times its too high in the air and every once in awhile it gets it right. I have tried adjusting Z probe hieght in eeprom settings but they seem to have little effect since accuracy isnt really there.
After homing I assume you are at x=0 so activating goes to x=-45 (virtually). So you need to run G1 X45 to move 45 to right and then activate probe. Also make sure that the area where you probe is not left of x=45.
