X end switch not stopping motor movement...
all of a sudden my x end-switch no longer stops the motor from moving, it tries to keep going past the switch. I changed the switch and wire and still same,, M119 shows that the switch is L when not triggered and shows H when triggered so its sending the correct info to the board so I figured the firmware got corrupt somehow so I reinstalled the firmware and still not working, same results..
I changed nothing, it just stopped working...
Any ideas?
Any ideas?
I have removed the drive belt and ran the motors and still the x motor will run fine for a few seconds then stop working (sits there making a growling type noise) , it has to be something other then repetier at this point....
