Manual Mesh after homing Z
hey guys
Maybe i missed it BUT i have looked for something similar. I have a CoreXY 300x300x500. It works great and corners are level BUT there are areas where it dips. I have tried pieces of tape and paper between the bed and glass BUT on FULL bed prints it is sometimes a problem.
Is there a way i can do the normal Z MIN homing then MANUALLY flip down a BL touch or micro switch and then do a manual levelling exercise? OR even a automated levelling with a Z min ens stop only? i.e. using a Z offset greater than the endstop activation point?
Hope i made sense.
Hope i made sense.
Thanks for the help. I was messing with this last night and it worked VERY well (obviously) is it also possible to have this done automatically using a min Z end stop and not a Z max? for the last 2 years i have always manually leveled but big beds are more of a challenge if you want a 0.2 first layer you are in trouble!! 0.3 you are still ok.
