extruder / part cooling Fan
today added the 2nd output for extruder 1 extruder 0 worked great (eventually add a 3rd extruder) (ramps 1.4)
think the heatbed mosfet was controlling the part / extruder fan. i could turn on or Off with the repetier firmware now with the configuration change of adding the 2nd extruder the fans stay on full.
Read some place here that this may be due to adding the 2nd extruder output (dont think that is what i want as each has it own cooling fan) But this was the fan control (in general) previously working.
How do i reset so this works (used the configurator o92.9 version with the config H (ps the one output controlled the part cooler and the fan for the extruder. had it set to come on 25% of the time and that worked great.
Also notice i don't have a heatbed slider anymore (this maybe related) seems to me i am missing or need to correct the line in configurator 092.9 someplace any ideas
not sure which portion of config h this is in, let me knwo and i can post :>)
thanks in advance
