And how i can change the homing direction? because the gereral direction o the Z axis still good, i ask go up, it go up, the problem is juste the homing dir ant the endstop
I run the eeprom_clear sketch before I upload a new firmware so it will be fresh. You stated things aren't changing. This may help. In the Arduino program its under File - Examples - EEPROM - eeprom_clear
#define Z_HOME_DIR -1
but don't do anithing
