Problem with Z axis
Hello there
I've my own 3D printer and all work good apart of my z axis, when he want to go home he go max and not to min sensors and when i push the sensors nothin happend, I'm realy confused.
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 100
#define MAX_FEEDRATE_Y 100
#define MAX_FEEDRATE_Z 10
#define HOMING_FEEDRATE_X 20
#define HOMING_FEEDRATE_Y 20
#define HOMING_FEEDRATE_Z 5
#define HOMING_ORDER HOME_ORDER_XYZ
#define ZHOME_PRE_RAISE 2
#define ZHOME_PRE_RAISE_DISTANCE 50
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define Z4_STEP_PIN   ORIG_E3_STEP_PIN
#define Z4_DIR_PIN    ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 0
#define ENDSTOP_X_BACK_MOVE 2
#define ENDSTOP_Y_BACK_MOVE 2
#define ENDSTOP_Z_BACK_MOVE 1
#define ENDSTOP_X_BACK_ON_HOME 0
#define ENDSTOP_Y_BACK_ON_HOME 0
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
«1
  • You need
    #define Z_HOME_DIR -1
    Test z min endstop using M119 if it works correct.
    If first move goes up you might have configured direction wrong and need to invert z direction flag.
  • edited January 3
    What i have already, the sensor still not detected by repetier, he work normaly and the conetor are good
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define X_MAX_LENGTH 210
    #define Y_MAX_LENGTH 210
    #define Z_MAX_LENGTH 220
    #define X_MIN_POS 10
    #define Y_MIN_POS 10
    #define Z_MIN_POS 0
    #define PARK_POSITION_X -2
    #define PARK_POSITION_Y 10
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 5
    #define DISTORTION_YMIN 5
    #define DISTORTION_XMAX 210
    #define DISTORTION_YMAX 210
  • Repetier said:
    You need
    I've chanched this and the problem still the same :(
  • Did you also change
    to switch direction?
  • Yes the direction is good nnow but the homing move don't detect if my endstop is trigered or not
  • #define X_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_Z_DIR 1
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 10
    // ##                           Movement settings                                          ##
    // Delta settings
    #define MAX_FEEDRATE_Z 2
    #define MAX_JERK 20
    #define BAUDRATE 250000
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 40
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 0
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 0
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 1
    #define LANGUAGE_ES_ACTIVE 1
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 1
    #define LANGUAGE_TR_ACTIVE 1
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
  • Check manually what M119 reports and if zmin changes to H when you trigger it. That is what gets tested and if endstop is configured wrong it will not switch.
    how?
  • Send M119 to the printer and see in log what it responds. Hosts allow sending manual command. How did you test endstops before?
  • edited January 4
    Normaly with homing botton
  • edited January 4
    okay It decect well, i see low and high, is the progam the problem
  • I send it using the G-Code window under Manual Control. You cane test with nothing activated then activated manually. All 3 should change state and read the same activated/unactivated.
    This would be done by hand.
  • I did it, the code say is tigerred and when i ask Z to go home, he don't stop
  • Can you copy/paste the result when you do not trigger it and when you trigger it.
  • Apperently, the program detect it but won't stop when he go to homing position
  • are you shure you have right directions/homing ?
    distance from nozzle to bed = 0 means zmin.
    max. possible distance from nozzle to bed means zmax.
    as you did not write what type of printer you have it´s hard to follow
  • it's a cartesian printer
  • I intend to change this but still going up
  • edited January 6
    is nozzle moving or bed moving?
  • home moving
  • what i mean is which part moves when homing.
  • The Z axis, the extrudor go up
  • and where ar the endstops mounted?
    on top of z-axis or on bottom?
  • When i do the M119 command to test the Z endstop repetier detect when is triggered o not, and when I ask the printer to go to his homing position, he go up AND don't matter if the sensor is triggered or not, that's my doble problem
  • please answer the question
    On the min
  • i mean where the endstopswitches are mounted....
    on top of z-axis or at the bottom
  • Bottom, to detect when it go to bed
