Dualhead temperature control - offset until switching heads for first time
in Bug Reports
I'm labelling this as a bug but it may be something else.
I have a dual head printer in beta test
Controller is a Megatronics V2
Firmware is Repetier 0.91
Host is Rep 1.05
Symptoms are:
1) Starting from a freshly powered up cold system, bed and both extruders measure ambient temperature, all within +/- 0.5C. Turn both heads on, first extr 1 and a second later extr 2, both with a setpoint of 225C
2) Track temperatures in Reptier Host (RH), extruder 1 selected and shown on temperature curve, both extruders monitored on bar graphs, do not switch selected extruder in RH
manual control panel, E1 settles at 225C and E2 at 211C as seen on the bar graphs, but both heads
are at around 225-230 as measured with an external reference t/c.
3) Now switch heads in RH, so E2 is selected, the RH temperature curve now shows the
temperature as being low and the system immediately reacts and brings
E2 up to 225C and both extruders settle at 225C as indicated on the bar graphs- except if you check with an
external t/c it is actually more like 235-240C
4) In RH now switch back to E1 and both extruders stay at indicated 225C
Any suggestions, any further info I can supply to help troubleshoot ?
r/Andrew
Host is Rep 1.05
Symptoms are:
r/Andrew
22:38:22.407 : N136 T1 *31
I agree it doesn't make sense so checked again and got the same signature. Even tried reversing the t/c and heater wiring on my system and it is still the reported extruder 2 that shows this strange effect.
I guess the next step is to reload the firmware and see if if something changes.
Andrew
