Z probe measurings points
When i set new measurings points in the firmeware and use G32 S0 it seem if the printer is using other points then what is set in the firmeware
  • Did you change them in eeprom?
  • edited June 2015
    Don't they change when you rewrite the firmeware
  • No, that is the idea with eeprom. You can change afterwards and they will survive new uploads.
  • oke found it
    just having a problem with the host under linux mint.
    I only can change 1 setting at a time, when i tried to change 2 at time the host crashes
  • In next 1.5 release we have rewritten that crashing part,
