Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
Extruder & Bed
Z probe measurings points
Deluka
June 2015
in
Extruder & Bed
When i set new measurings points in the firmeware and use G32 S0 it seem if the printer is using other points then what is set in the firmeware
Repetier
June 2015
Did you change them in eeprom?
Deluka
June 2015
edited June 2015
Don't they change when you rewrite the firmeware
Repetier
June 2015
No, that is the idea with eeprom. You can change afterwards and they will survive new uploads.
Deluka
June 2015
oke found it
just having a problem with the host under linux mint.
I only can change 1 setting at a time, when i tried to change 2 at time the host crashes
Repetier
June 2015
In next 1.5 release we have rewritten that crashing part,
Sign In
or
Register
to comment.
oke found it
