Printer stops communicating when printing is started
Hello,
I have a two up as my 3d printer. I´m trying to get it working on my computer since I´ve recently changed it. After setting up the configuration for the printer, making shure baud rate is ok and all of that, I tryed using manual controls in order to check the communication between the pc and the printer itself. Worked fine. I would heat up the extruder perfectly and the header with no problem.
After all of that was done, I wanted to print something. Slice the 3D model, click print and... nothing. The printer was supposed to heat up the extruder, but it´s temperature just decreased. After some minutes I stopped the print and try to move the printer with manual controls myself. Wasn´t working. I disconnected and reconnected and they came back, but every time I happened to click "print" stopped.
I have no idea how to fix this issue so I came here for help,
Thank you.
Thank you.
Thanks.
repetier.log
It did not stop working - it started heating the bed to 50°C and will only continue when finished. Then it will heatup the extruder if it is still not at target temperature. Depending on printer type this takes 3-15 minutes for most printers.
Only if your printer never reaches 50°C it will wait for ever or generate an error failing.
