Two IP addresses necessary?
We installed the Image
V12 with Repetier-Server 0.90.7 for Raspberry Pi, on a RPi3 B+. We
connect to the server via hard wire only, programmed our DNS server DHCP with
the MAC address for a static IP, and connect to it via web browser. This
worked for a month and many prints, until we recently tried adding a camera.
We are not sure how, but somehow we caused a change while
trying to add a camera. The repetier-server now hits up our DNS server
twice, and obtains two IP addresses. For the same network interface eth0,
there are two different QR codes and two different IP addresses... the same two
IP addresses provided by our DNS server DHCP. In order to get it to work,
we had to remove the static IP address entry from our DNS server DHCP.
Otherwise it would connect, work for about 1 minute, and then drop connection
for good. The DNS server would deny that 2nd attempt for the same MAC
address, and it looks like the repetier-server would respond by dropping eth0
entirely. A temporary 1 minute connection could repeatedly be had by
unplugging the ethernet and plugging it back in. We could also
easily connect via WLAN AP mode. Our DNS DHCP static entry called the server by a unique name…
i.e. ‘our printer’. With that entry removed, the DHCP provides two IP
addresses with the name that the repetier-server insists on: 'repetier-server'.
We are not sure how we accomplished this. We did very
little to get the camera working, and we tried unplugging it and putting
everything back. During this, we entered in a password (changed it) for
the pi login, to connect via SSH and sudo nano the config for the camera.
Maybe we triggered some background software / configuration changes? Our server name
under global settings is ‘our printer’.
We do not see where the name 'repetier-server' is coming from. We have not populated the 'Server Domain
Name' field. Without touching it, I felt the behavior is odd that
it is now hitting up the DNS DHCP server twice and obtaining two IP addresses for the same network
interface eth0.
There repetier-server comes from is easier. That is the hostname of the pi image. Go to wlan settings->Connection Settings. There at the top you can change the hostname to whatever you want. This gets also reported as zeroconf uisng avhci so you can enter e.g. in smartphone repetier-server.local as address if it is in same network. Windows requires bonjour support to find it that way.
