bed leveling routine problem
Hello
i have a problem with the bed leveling and i think it's because of a problem with the bed leveling routine
i set the three z probe points to probe the point near the A tower after that the point near the B tower and then the point near the C tower and i send g32 s2
the probe tried to move to the point near the A tower and then moved down to measure all points
the result was that the firmware thinks that the a slider must be lower and after homing it always makes it lower than the others if the auto bed leveling is turned on
i tried to change the probing points to make them B then A then C the same problem moved to the B slider and that means that the problem is with the first point always
i think that the problem with the bed leveling itself because the carriage moves near the tower before moving down and that limits the movement of the slider of the tower
i tried to send g32 after moving the carriage down so all sliders can move up and down freely and every thing went ok
so please Repetier tell me what you think
