G30 is working but G32 S2 is not.
So to make a long story short I built a gantry style printer and had z probe working just fine and then I decided to reflash the firmware for multiple reasons and now after getting everything set back up I can not get G32 bed leveling to work. The probe will go down and test on spot then come up to probe another spot then shut down cause of an error.
Error: z-probe did not untrigger on repetitive measurement- may need to increase distance.
The other thing is the G30 works just fine.
You might be on the edge as first points worked.
