Slic3r PE cost is always 0
Hello,
When using repetier host 2.1.3 and slic3r PE (1.41.0, but also older versions), but estimated cost is always zero in repetier host.
When using the same profile in slic3r directly, the cost is calculated correctly. So I think that it's a bug of Repetier Host.
Can you guys look into it ? Thanks
Do you think that you could add those infos in the "Printing statistic" panel in the "print preview" tab?
TY
