Delta extruder Offset
Hello to you all!
I have questions concerning the origin point from which you enter the extruders
x/y offset.
I have a custom 3 extruders delta printer.
I have read that ‘’ these coordinates are the difference to the position of the
first extruder’’ but where do you input the coordinates of the first extruder?
Also I cannot enter decimal values, for example if a enter
26.25mm it tell me to enter either 26mm or 27mm, is there a way to change that?
Thank you!
I am using the Repetier-Firmware configuration tool for version 0.92.3
