Delta extruder Offset
Hello to you all!
I have questions concerning the origin point from which you enter the extruders
x/y offset.
I have a custom 3 extruders delta printer.
I have read that ‘’ these coordinates are the difference to the position of the
first extruder’’ but where do you input the coordinates of the first extruder?
Also I cannot enter decimal values, for example if a enter
26.25mm it tell me to enter either 26mm or 27mm, is there a way to change that?
Thank you!
  • I am using the Repetier-Firmware configuration tool for version 0.92.3
  • For delta printers the origin is the center of your extruder plate. Only for cartesians you have a choice.
    You can ignore the error message you see. If you reload you should also have a version that does not display the message.
  • Thank you!
