sd card read error
Am having adruino mega 2560 and ramps 1.4 with reprap discount smart controller with repetier 0.92.9 firmware
sd card is detecting and files are showing when its connected over usb with the laptop just fine.
but when i connect with the DC supply its not detecting the sd card but it says sd card inserted.
please help me out of this issue ....
Apart from this there is no difference in code for the start methods.
but its not doing the job
.and also when i connect with dc supply laptop trackpad works weirdly
Is there anything else drawing much current like a servo (which should have it's own power and not use the 5V from board). No idea what else could cause such problems.
but i have noticed that when i insert the sd card the lcd turns dim both when connected via usb or dc power..
should i replace the ramps 1.4 or adruino or the lcd , like which one should i replace 1st and check..
please help me with this
i tried different sd cards too but same result
