Anet A8 ( Melzi ) v1 firmware problem
Dear developers, I made in the past Anet A8 configuration, it works very well. I try to make new version using for the beggining same configuration imported from ver. 0.92 durring compilation I'm getting such error, is this realy means there is not enouge space ?
c:/users/tomasz/desktop/kalimba/arduino-1.8.0 (with apim)/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ld.exe: C:\Users\Tomasz\AppData\Local\Temp\arduino_build_101350/Repetier.ino.elf section `.text' will not fit in region `text'
Next....
If it realy is like I suspect, Can we begin some closer cooperation to get one more feature inside of 0.92 regarding to ABL system?
I'm owner of Garage-Makezone.eu we have more than 7000 users in our Anet A8 Groups at FB. This one add feature is pre-rise of head when G28. We have provide open scource project of ABL sensor similar to BL Touch that do not required external power supply. I was hope we will use repetier as dedicated firmware for it. Problem is that pre-rize exist only in 1.0
HallON project page at thingiverse. https://www.thingiverse.com/thing:2838259
At the moment we are using Marlin, but I do not like way is developt also ABL system problems with fact that since FEB they did nothing to solve it force me to ask You guys for help. Previously provided configuration of 0.92.9 Repetier for our users give very good feedback.
Next....
#if Z_HOME_DIR < 0
#if ZHOME_PRE_RAISE == 1
if(zaxis && Endstops::zProbe())
PrintLine::moveRelativeDistanceInSteps(0, 0, ZHOME_PRE_RAISE_DISTANCE * axisStepsPerMM[Z_AXIS], 0, homingFeedrate[Z_AXIS], true, true);
#elif ZHOME_PRE_RAISE == 2
if(zaxis)
#endif
#endif
So if you add this and add ZHOME_PRE_RAISE and ZHOME_PRE_RAISE_DISTANCE in manual config of tool it should work also in 0.92.
Raise Z before homing z axis
0 = no
1 = if z min is triggered
2 = always
This is for printers with z probe used as z min. For homing the probe must be
at a minimum height for some endstop types, so raising it before will help
to make sure this is guaranteed.
#define ZHOME_PRE_RAISE 0
// Distance in mm to raise if required
