Beeper troubles : M300 Doesn't work but M120 does...
Hello !
As the title says, i'm able to perform M120 without trouble but M300 simply doesn't do anything !
I'm using a ReprapDiscount 128 64 Screen with a Ramps-FD due board.
How can I make It work ?
M300 Sfrequency Pmillisoconds
we only call teh arduino ::tone function on same pin. If it was not just unhearable it might be a problem with timer usage that could not be set to PWM for a frequency. I'm not so familiar how the due version works here.
https://forum.repetier.com/discussion/3914/is-m300-g-code-working
https://forum.repetier.com/discussion/4833/missing-beep-m300
