Wrong axis label for second extruder in g-code.
The g-code generated with a dual extruder configuration using Slic3r Prusa and Mach3 gcode flavor sends ALL of the extruder positions to the A axis, when the second extruder should use the B axis. Is there a configuration setting I am missing to specify the axis label for a second extruder? Using Repetier Version 2.1.2.
