More dualx related questions
In order to make my printer even more reliable, I am planning to implement
Thanks a lot - again! Looking forward to V2 of your firmware, although I have little wishes for the current version
- MULTI_ZENDSTOP_HOMING:
I assume that I can have dual z-min homing (with dual z motor steppers of course) to level the carriages
AND BLTouch for probing and bed-leveling. Am I right? - Dual jam detection? Guess that wont be available in V1, or is it?
Multi z endstop homing is possible, but if you also use a z probe it gets complicated. So hope you mean multi z max homing. Also I have no dual x with autoleveling so can not say much about if it works or not. Would work like on normal cartesians but with the 2 x axis this might have side effects when you switch.
We have no function for detecting double and long press click, so can not put functions on it. Sounds like a nice idea for the new V2 interface.
So why do you need it? Knowing what it is fore allows better thinking about what is possible.
