How to use end stop at max position
I'm building a printer, and I'm currently testing end stop.
I have an issue with Y endstop (which is placed at max Y). When I launch a homming, the first step is OK: the axis go to the top of Y and hit the endstop, after it go backward,and then go back to the endstop. The issue is here: it do not stop or go back at the second hit, it even looks to speed up in the endstop.
I have trie multiple configuration but I did not get something clean...
What are the expected configurqtion for this kind of setup?
Best regards
Best regards
#define ENDSTOP_Y_BACK_MOVE 5
is a positive value. Negative would be in the endstop and that move does not test endstop! So with negative value you should exactly get your behaviour.#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Y_BACK_ON_HOME 30
I can see the first hit followed by a back move (5mm), and the second hit followed by another back move(30mm). After this there is a last move of 20 mm in the positive direction. With the ENDSTOP_Y_BACK_ON_HOME set at 30 there is no more crash, but I don't understand the last move
