G28 + Z Endstop min
Hello,
I´ve trying to configure G28 (using graber i3 printer) without success:
My scenario is: X/Y endstop are in min pos with X-10 position and my Z min is an endstop at right side of hotend, with servo.
When I run G28, X go to -10, Y to 0 and Z starts to go down but in this position Z probe is completely out of bed! Impossible to work.
if I set the tags:
if I set the tags:
#define ENDSTOP_X_BACK_ON_HOME 100
#define ENDSTOP_Y_BACK_ON_HOME 100
the G28 works perfectly (Z probe inside the bed area) but when it finish, X and Y are set both with 0, but they are at 100 in real positioning...
Am I doing some config mistake? How to solve it? I just want to do a G28 with the Z probe in a valida bed area, not at the 0 position.
thanks
my config file:
https://pastebin.com/0R6d7jRz
thanks
my config file:
Thank you.
