New to Repetier Firmware and having E-Step issues
Alright I am a former Marlin Firmware user and have recently swapped to Repetier as I was told it would be better for doing multi extrusion with my custom 3D Printer design. I have been building 3D Printers for just over a year now but I have run into a problem when configuring the firmware. I have set everything up and everything seems to work correctly apart from my E-Steps for all stepper motors. When I was using Marlin I used X:80, Y:80, Z:400, E0:837, E1:837 and it worked completely fine, I have inputted the same E-Steps into Repetier expecting it to work but I am finding that it is not correct and in fact miles off working correctly with my Z axis moving a fraction of a mm when set to move 10mm. Any ideas or info that would help me figure it out would be greatly appreciated. (Unable to upload my Configuration.h file on here for some reason)
Also Repetier host has a built in eeprom editor in the config menu
Now you can use the select/deselect scripts to push filament in/out your y-tube. Make sure to always disable with extruder 0 selected as it will forget the selected extruder and always assume extruder 0 at startup!
