problems with second extruder.
Hi Everybody,
I am having problems with most recent repetier firmware. I tried to find answers to my problem in forum but nothing came up. I upgrated my clone of TAZ to print using two heads. I configured firware online, make necessary changes in pins, uploaded to my MKS Gen V1.3 board.When I tested the new setup. it did not read the temperature of the second heater (which was on temp_2_pin and was connected to A15 pin) . I switched the connector to port temp_0_pin (pin A13) and it showed the correct temperature. I mention this to show that sensor and connections are Ok, something wrong with my Configuration or pins files. Also it does not turn off the second print cooler fan. Initially it was connected to aux1 pin D2. Then I moved it to aux2 pin A9, but nothing changed. The fan spines all the time. I would be very thankful if somebody can help me to figure out the problem.I tried to attach my Configuration and pins files but could not do it. The attach button complains that file is not allowed. I will copy here parts that are related to my problem.
#define EXT1_X_OFFSET 30
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 700
#define EXT1_TEMPSENSOR_TYPE 97
#define EXT1_INVERSE 0
#define EXT1_ENABLE_ON 0
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 3
#define EXT1_PREHEAT_TEMP 190
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_EXTRUDER_COOLER_PIN 57
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
 and from pins.h file
#if MOTHERBOARD == 3 || MOTHERBOARD == 33 || MOTHERBOARD == 34 || MOTHERBOARD == 35 || MOTHERBOARD == 39 || MOTHERBOARD == 38
#define KNOWN_BOARD 1
#if !(defined (__AVR_ATmega1280__ ) || defined (__AVR_ATmega2560__ ))
#error Oops!  Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu.
// uncomment one of the following lines for RAMPS v1.3 or v1.0, comment both for v1.2 or 1.1
// #define RAMPS_V_1_3
// #define RAMPS_V_1_0
#ifdef RAMPS_V_1_3
#define ORIG_X_STEP_PIN         54
#define ORIG_X_DIR_PIN          55
#define ORIG_X_ENABLE_PIN       38
#define ORIG_X_MIN_PIN          3
#define ORIG_X_MAX_PIN          2
#define ORIG_Y_STEP_PIN         60
#define ORIG_Y_DIR_PIN          61
#define ORIG_Y_ENABLE_PIN       56
#define ORIG_Y_MIN_PIN          14
#define ORIG_Y_MAX_PIN          18
#define ORIG_Z_STEP_PIN         46
#define ORIG_Z_DIR_PIN          48
#define ORIG_Z_ENABLE_PIN       62
#define ORIG_Z_MIN_PIN          15
#define ORIG_Z_MAX_PIN          19
#define ORIG_E0_STEP_PIN         26
#define ORIG_E0_DIR_PIN          28
#define ORIG_E0_ENABLE_PIN       24
#define ORIG_E1_STEP_PIN         36
#define ORIG_E1_DIR_PIN          34
#define ORIG_E1_ENABLE_PIN       30
#define SDPOWER                  -1
#define SDSS                     53
#define ORIG_SDCARDDETECT       49
#define LED_PIN                 13
#define ORIG_FAN_PIN            10
#define ORIG_FAN2_PIN           9
#define ORIG_PS_ON_PIN          12
#define HEATER_0_PIN       9
#define HEATER_1_PIN       8
#define HEATER_2_PIN       7
// ANALOG NUMBERING
#define TEMP_0_PIN         13
#define TEMP_1_PIN         14
#define TEMP_2_PIN         15
#define E0_PINS ORIG_E0_STEP_PIN,ORIG_E0_DIR_PIN,ORIG_E0_ENABLE_PIN,
#define E1_PINS ORIG_E1_STEP_PIN,ORIG_E1_DIR_PIN,ORIG_E1_ENABLE_PIN,
 Thanks ,         Simon
  • Nobody had this problem.
  • Since you say you get wrong temperature that could explain why fan is always on. It is on when reported or set temp. is > 50°C.
    If you have no heated bed you can try TEMP_1_PIN for second extruder temperature. If not I can not say if pin number is wrong or pin is defect or you set it to digital by using the digital pin number somewhere.
    Other analog pins will not work as this is not just a analog pin, but also a voltage divider with 4.7K resistor. If you have such a resistor you can of course make the same schematic for any analog pin by hand.
  • Thanks a lot for response. Meanwhile i could solve the problem with fan. I switched it to pin A9/D63. Initially I gave pin number 9 as analog numbering and it did not work. Later I gave it as pin 63 and it solved the problem. I decided to do the same with A15. When in pins.h I as TeMP-2-PIN i give 15 it shows 380 degrees and does not react on temperature. When 15 I replace with 69 it shows 32 degrees but again did not react on temperature. I think I have some problem with analog numbering. Is there a way to show that we are addressing analog input. In Arduino I can use A1..A15, while in Repetier when I use numbering with A I am getting an error in compilation.
    Thanks    Simon
  • Output pins ALWAYS use digital pin numbers. Analog inputs over ADC are always analog pin numbers. On/off input also use the digital pin numbers.
