Both Z axis steppers are moving the oposite direction
2»
  • RAyWB said:
    before you wrote z is moving down... now you write z-is moving up....???????
    so you have to rotate both z motor connectors again ,
    lets do it step by step
    if you want to home x to the left side you have to move endstop to the left and set endstop xmin.
    YEAH!
    Just fixed it :D :D :D
    For the endstops:
    #define ENDSTOP_X_MAX_INVERTING true
    #define ENDSTOP_PULLUP_Y_MAX false
    #define ENDSTOP_PULLUP_Z_MAX false
    That works!
    #define X_ENABLE_ON 1
    #define Y_ENABLE_ON 1
    #define Z_ENABLE_ON 1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 200
    #define Y_MAX_LENGTH 200
    #define Z_MAX_LENGTH 180
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    This for the movements also!!!!!!!
    When home all: moves to X-0 and stops, moves to Y-0 and stops, then moves to Z-0 and stops.
    Now I have to get the thermistors and heaters to work
  • edited May 2018
    usually impossible ...
    xmin homing with x max endstop...
    think that will cause trouble later on
  • On the duplicator it was always X max if i recall correctly. To be sure I always can ad an additional endstop for min just to be sure?
    Next on my list is getting the heaters to work. It now gives decoupled error.
