Bricked LCD screen (2 rows of white Squares)
I'm new to 3d printers, only assembling my first printer 2 weeks ago, the printer I assembled worked great for 1 week and made 5 successful prints (2 maker coins, 2 upgrades, 1 blade of chaos) the day after the final print when I turned the printer on it had 2 rows of rectangles on the screen. I've been trying to look into this for a week but with little success on finding a solution. most of what I could find is that it relates to firmware.
The printer I have I ordered off Walmart.com and it was stated as a anet A8, Prusa I3, Reprap.
The frame of the printer has Prusa I3 engraved, and from what I could find online the main board is a Melzi.
The file in the SD card states the printer is a Tronxy X6D.
Any help would be appreciated Id hate to return or put more money into this unless I know the results are absolute, thank you.
Printing is normally not affected from this error, only not so nice to have lost the display.
These cables get contact by cutting the pins through the plastic. If the cable is not positioned 100% correct during this it can have bad contacts. If you have a multimeter you could test each contact and see if it gets through to the other side. Also test how many contacts on the other side respond. Sometime it hits 2 pins at once and that would also be a problem just like having no contact.
If you did not change firmware which worked before I think it is more hardware related.
