CNC Mode M3,M4 Sxxx GCode PWM not consistently interpreted
edited May 2018 in Bug Reports
Only the first M3,4 Sxxx spead is read unless a M5 is sent the rpm doesnt change
I 'fixed' it.......
void CNCDriver::spindleOff()
    spindleRpm=0;
    spindleSpeed=0;
    if(direction == 0) return; // already off
    if(EVENT_SPINDLE_OFF){
      #if CNC_ENABLE_PIN > -1
        WRITE(CNC_ENABLE_PIN,!CNC_ENABLE_WITH);
      #endif
    HAL::delayMilliseconds(CNC_WAIT_ON_DISABLE);
direction = 0;
/** Turns spindle on. Default implementation uses a enable pin CNC_ENABLE_PIN. If
CNC_DIRECTION_PIN is not -1 it sets direction to CNC_DIRECTION_CW. rpm is ignored.
To override with event system, return false for the event
EVENT_SPINDLE_CW(rpm)
void CNCDriver::spindleOnCW(int32_t rpm)
  if  (rpm > CNC_RPM_MAX)
    rpm=CNC_RPM_MAX;
  spindleSpeed=map(rpm,0,CNC_RPM_MAX,0,CNC_PWM_MAX);  // linear interpolation
  spindleRpm=rpm;                                     // for display
  if(direction == 1)
        return;
    // spindleOff();
    // spindleRpm=rpm;// for display
    direction = 1;
    if(EVENT_SPINDLE_CW(rpm)) {
      #if CNC_DIRECTION_PIN > -1
        WRITE(CNC_DIRECTION_PIN, CNC_DIRECTION_CW);
      #endif
        WRITE(CNC_ENABLE_PIN, CNC_ENABLE_WITH);
      #endif
    HAL::delayMilliseconds(CNC_WAIT_ON_ENABLE);
CNC_DIRECTION_PIN is not -1 it sets direction to !CNC_DIRECTION_CW. rpm is ignored.
EVENT_SPINDLE_CCW(rpm)
void CNCDriver::spindleOnCCW(int32_t rpm)
{ if  (rpm > CNC_RPM_MAX)
    rpm=CNC_RPM_MAX;
  if(direction == -1)
      return;
  spindleOff();
  direction = -1;
  if(EVENT_SPINDLE_CCW(rpm)) {
        WRITE(CNC_DIRECTION_PIN, !CNC_DIRECTION_CW);
     #endif
     #endif
  • I see in official version that it tests same direction. So fine as long as rpm is not relevant. Fix for official driver would then be
      spindleSpeed=map(rpm,0,CNC_RPM_MAX,0,CNC_PWM_MAX);// linear interpolation
        if(direction == 1 && spindleRpm == rpm)
            return;
        if(direction == -1) {
        spindleOff();
        spindleRpm = rpm;// for display
        direction = 1;
    #endif
    #endif
    I also added spindleOff to execute only when direction changes. I thing the extra pause is a good thing instead of stopping on full speed.
    Setting the speed would be done in EVENT_SPINDLE_CW which is then hardware specific.
  • and testing for CNC_RPM_MAX ? , I think there should be also an CNC_RPM_MIN under this spindle must go to zero RPM a stalled spindle will overheat and kill itself.
    In hindsight I think a simple #ifdefine in conditions., with a simple switch statement or ifthenelse in extruder  would solve the problem for 90% of the applications the input to PWM_POS[] is either
    1. Thermal Input in FFF mode
    2. spindleSpeed in CNC mode
    3. LazerIntensity in Laser mode to a
    chosen PWM channel, there are very few options left in anycase.
    and output a selected PWM channel.
     No need for coding and amateurs like me to scratch in the code, i like it simple.
  • I have asked my CNC friends and appart from cutting left hand thread or finishing with a toolchange no one thinks a CCW is important, probably beyond the application for your users, a PWM output then solves all problems as the PWM output can be a simple on off signal as well, both for thermal/laser/cnc or proportional. very clean and simple
  • Not owning a real CNC I'm not really familiar with all the wishes here.
    CNC_RPM_MIN do you mean there is a minimum and otherwise a spindle would stall? Because we do not measure real speed. In fact rpm gets computed from interpolation for pwm, that is all.
    PWM is the other problem. For V2 I have already a solution for it as we there can define PWM inputs that get mapped to a pwm function of choice, which is preferably a hardware pwm. For V1 we have no generic PWM and only use software PWM with 15Hz or faster with lower resolution. That normally is not suitable for laser/cnc input I guess, which is why I never wrote a general software pwm solution here. And on Mega boards we use already some timers internally so there are only 2 HW timers for pwm creation free, but we have no general system for it. Hence the not so nice trick with own event to provide the correct code for it.
  • edited May 2018
    Yes if under a minimum speed it will stall, exactly the same problem you have on fan.  simplest spindle is a PWM brush motor, or an openloop control and they dont have much torque at low speed,  to do a constant torque zero speed vector control on a spindle is a bit extreme and I would not think your target market will have CNC machines with this hardware.
    That PWM is perfectly suitable for both Heater/Spindle?Laser ,  after I remapped spindleSpeed to the HE2 channel on the Rumba board it drives a spindle perfectly. I have done a little board that takes the PWM from HE2 isolate it and drive 15A in a small spindle.
    If you want the design and PCB layout I am happy to share it.
    You can do the general PWM remapping, its working and I think that's all the users are asking for, not a full blown CNC with tool offsets, tool diameter etc etc.
    On the laser I use the pin which you have already implemented, redirect it to PORT30 on the RUmba and will use that as a gate, LaserOn/LaserOff, the PWM could be mapped exactly like a spindle with a little interface to pulse the power, no need for high resolution or high speed on those PWM's.
    (**********************) Would you consider this request?
    3. LaserIntensity in Laser mode to a
    im not sure if I explained myself well, your code is perfect as is ,just allow  a HE, spindleSpeed and LazerIntensity share the same PWM, It is the users responsibility to on a hardware level interface that PWM to a
    1. Heater/ThermoFan
    2. Spindle
    3. Laser
    You have already implimented all the code with FAN_Thermo ,  bar 3 instruction.
    #if FAN_THERMO_PIN > -1          /*********** DJC This will be PWM for Spindle in CNC Mode *********************/
            if(act == &thermoController)
                if(act->currentTemperatureC < Printer::thermoMinTemp)
                    pwm_pos[PWM_FAN_THERMO] = 0;
                else if(act->currentTemperatureC > Printer::thermoMaxTemp)
                    pwm_pos[PWM_FAN_THERMO] = FAN_THERMO_MAX_PWM;
                else
                    // Interpolate target speed
                    float out = FAN_THERMO_MIN_PWM + (FAN_THERMO_MAX_PWM - FAN_THERMO_MIN_PWM) * (act->currentTemperatureC - Printer::thermoMinTemp) / (Printer::thermoMaxTemp - Printer::thermoMinTemp);
                    out = CNCDriver::spindleSpeed; //****************  DJC ****************
                    if(out > 255)
                    else
                        pwm_pos[PWM_FAN_THERMO] = static_cast<uint8_t>(out);
                continue;
    all it need is this..
    if mode==FFF then
    elsif  Mode==CNC
       out = spindleSpeed  /// RPM mapped to 0..255 with M3,M4,M5
    elseif Mode==Laser
       out = LaserIntensity /// controlled by M3 0...100%
    This makes your software universal and simple without any extra CPU load.
    I wouldnt even need to code under event handlers.
    The user can with a simple switch or pin interlock that the HE doesnt heat up if he use a spindle or lazer
    In reality I think the user will plug in a HE or a Laser or a Spindle leaving all of them on a machine doesnt make sense
    best regards
  • Interesting extension to my new pwm system for V2. I could there solve the min pwm with a general class that inputs a normal pwm and makes it min value sensitive. I also checked the same pin for all problem and this also gets solved with the new system. So one more point why the new solution is superior.
    For V1 I will not change it. That gets too confusing with all the special cases I would have to consider if only 2 share same pin, or none plus that the system is not that flexible so implementation for general solution starts using many if/#if cases. One of the reasons I started with V2 as this system has proven to be too unflexible for the raising need of special solutions.
