CNC Mode M3,M4 Sxxx GCode PWM not consistently interpreted
Only the first M3,4 Sxxx spead is read unless a M5 is sent the rpm doesnt change
I 'fixed' it.......
I 'fixed' it.......
void CNCDriver::spindleOff()
spindleRpm=0;
spindleSpeed=0;
if(direction == 0) return; // already off
if(EVENT_SPINDLE_OFF){
#if CNC_ENABLE_PIN > -1
WRITE(CNC_ENABLE_PIN,!CNC_ENABLE_WITH);
HAL::delayMilliseconds(CNC_WAIT_ON_DISABLE);
direction = 0;
/** Turns spindle on. Default implementation uses a enable pin CNC_ENABLE_PIN. If
CNC_DIRECTION_PIN is not -1 it sets direction to CNC_DIRECTION_CW. rpm is ignored.
To override with event system, return false for the event
EVENT_SPINDLE_CW(rpm)
void CNCDriver::spindleOnCW(int32_t rpm)
if (rpm > CNC_RPM_MAX)
rpm=CNC_RPM_MAX;
spindleSpeed=map(rpm,0,CNC_RPM_MAX,0,CNC_PWM_MAX); // linear interpolation
spindleRpm=rpm; // for display
if(direction == 1)
return;
// spindleOff();
// spindleRpm=rpm;// for display
direction = 1;
if(EVENT_SPINDLE_CW(rpm)) {
#if CNC_DIRECTION_PIN > -1
WRITE(CNC_DIRECTION_PIN, CNC_DIRECTION_CW);
WRITE(CNC_ENABLE_PIN, CNC_ENABLE_WITH);
HAL::delayMilliseconds(CNC_WAIT_ON_ENABLE);
CNC_DIRECTION_PIN is not -1 it sets direction to !CNC_DIRECTION_CW. rpm is ignored.
EVENT_SPINDLE_CCW(rpm)
void CNCDriver::spindleOnCCW(int32_t rpm)
{ if (rpm > CNC_RPM_MAX)
rpm=CNC_RPM_MAX;
if(direction == -1)
return;
spindleOff();
direction = -1;
if(EVENT_SPINDLE_CCW(rpm)) {
WRITE(CNC_DIRECTION_PIN, !CNC_DIRECTION_CW);
#endif
#endif
spindleSpeed=map(rpm,0,CNC_RPM_MAX,0,CNC_PWM_MAX);// linear interpolation
if(direction == 1 && spindleRpm == rpm)
return;
if(direction == -1) {
spindleOff();
spindleRpm = rpm;// for display
direction = 1;
#endif
#endif
I also added spindleOff to execute only when direction changes. I thing the extra pause is a good thing instead of stopping on full speed.Setting the speed would be done in EVENT_SPINDLE_CW which is then hardware specific.
In hindsight I think a simple #ifdefine in conditions., with a simple switch statement or ifthenelse in extruder would solve the problem for 90% of the applications the input to PWM_POS[] is either
1. Thermal Input in FFF mode
2. spindleSpeed in CNC mode
3. LazerIntensity in Laser mode to a
chosen PWM channel, there are very few options left in anycase.
and output a selected PWM channel.
No need for coding and amateurs like me to scratch in the code, i like it simple.
CNC_RPM_MIN do you mean there is a minimum and otherwise a spindle would stall? Because we do not measure real speed. In fact rpm gets computed from interpolation for pwm, that is all.
PWM is the other problem. For V2 I have already a solution for it as we there can define PWM inputs that get mapped to a pwm function of choice, which is preferably a hardware pwm. For V1 we have no generic PWM and only use software PWM with 15Hz or faster with lower resolution. That normally is not suitable for laser/cnc input I guess, which is why I never wrote a general software pwm solution here. And on Mega boards we use already some timers internally so there are only 2 HW timers for pwm creation free, but we have no general system for it. Hence the not so nice trick with own event to provide the correct code for it.
That PWM is perfectly suitable for both Heater/Spindle?Laser , after I remapped spindleSpeed to the HE2 channel on the Rumba board it drives a spindle perfectly. I have done a little board that takes the PWM from HE2 isolate it and drive 15A in a small spindle.
If you want the design and PCB layout I am happy to share it.
You can do the general PWM remapping, its working and I think that's all the users are asking for, not a full blown CNC with tool offsets, tool diameter etc etc.
On the laser I use the pin which you have already implemented, redirect it to PORT30 on the RUmba and will use that as a gate, LaserOn/LaserOff, the PWM could be mapped exactly like a spindle with a little interface to pulse the power, no need for high resolution or high speed on those PWM's.
(**********************) Would you consider this request?
3. LaserIntensity in Laser mode to a
im not sure if I explained myself well, your code is perfect as is ,just allow a HE, spindleSpeed and LazerIntensity share the same PWM, It is the users responsibility to on a hardware level interface that PWM to a
1. Heater/ThermoFan
2. Spindle
3. Laser
You have already implimented all the code with FAN_Thermo , bar 3 instruction.
if mode==FFF then
out = FAN_THERMO_MIN_PWM + (FAN_THERMO_MAX_PWM - F
elsif Mode==CNC
out = spindleSpeed /// RPM mapped to 0..255 with M3,M4,M5
elseif Mode==Laser
out = LaserIntensity /// controlled by M3 0...100%
This makes your software universal and simple without any extra CPU load.
I wouldnt even need to code under event handlers.
The user can with a simple switch or pin interlock that the HE doesnt heat up if he use a spindle or lazer
In reality I think the user will plug in a HE or a Laser or a Spindle leaving all of them on a machine doesnt make sense
best regards
For V1 I will not change it. That gets too confusing with all the special cases I would have to consider if only 2 share same pin, or none plus that the system is not that flexible so implementation for general solution starts using many if/#if cases. One of the reasons I started with V2 as this system has proven to be too unflexible for the raising need of special solutions.
