update to repetier host?
now that slic3r PE has been updated yet again and now use a different config format i wonder if repetier host will be updated?
  • Working on it, but latest Slic3r PE has problems importing some models correct. So maybe we update to an newer but not newest version as older versions did not have the problem.
    What do you mean with different config format? I know some new options, but I'm not aware format it self changed.
  • That is the one in all export ini I think. On export it should get splitted into the individual config parts we always used. At least I could already slice with 1.39.1 the old way. Only that there is a bug making many valid models unsliceable.
