CoreXY and steps/mm
Hello,
Does the current implementation of Repetier Firmware (version 1.0.2) still need doubled steps/mm for X and Y axis when using a CoreXY gantry system?
I guess when it's not in the config tool then it count's as disabled?
This activates nonlinear mode like for deltas so these settings take effecta s well (not delta specific). So select delta and set subsegments to 10 and updates per second to 10 and then switch back to corexy.
