RAMPS PLUS 2 motherboard configuration
Hi!
I need to configure repetier for the BT7200 ramps plus 2 card.
https://ae01.alicdn.com/kf/HTB1U68SSXXXXXXraXXXq6xXFXXXC.jpg
What settings to choose in the configuration utility. P.S. Perhaps someone has a basic circuit board? Thanks a lot.
  • Is it compatible to RAMPS 1.4? Never heard about it and googling does not show much. Ypou need to know the pinout of the pins so you can compare with pins.h if they match or to add a new section with new pinout. If you find a website with the pinout I might be able to help here.
  • Board used in k200 he3d printer and some other.
  • I found a firmware.
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 33
