Bed not heating when using Curaengine
When I use Curaengine as slicer, the Bed is not heating. Bed temperature on the window bottom stays OFF.
The printing tasks never ends. The progress bar goes up to 50% and that is all. It stops there.
When using Slic3r the bed heats and the print tasks finishes as expected.
Do I need to add any setting to enable heating bed when using Cura ?
{IF_BED}M190 S{BED}
in your start gcode?
This will use the hottest bed temperature set in the filament configuration you use. If this is 0 it will not add the line.
slic3r and cura start codes are not compatible to each over.
