Can't start print "could not activate z"
I go to print a calibration cube on my tevo tarantula and after the bed and extruder are heated, everything is homed and is about to start I get the message "could not activate z" and it stops, please help
  • Don't have this error message but we have
    Could not activate z-probe offset due to coordinate constraints - result is inaccurate!
    In that case you need a homing order with preheat (which can be set to 0). Then you can set homing position for z such that z probe can be activated and then it will also probe Z.
  • Repetier
    so which line do i edit in the config because there are multiple z probes for every axis
  • edited January 2018
    MikySpiky said:
    Repetier
    I also don't have automatic bed leveling if thats what it's trying to do then how do i disable it entirely?
  • HOMING_ORDER is the one you need to change here. But if you have no z probe that should not be the case except you have defined z probe as well. In config tool you can change homing order and it shows then the additional homing coordinates if you select the preheat version.
