Can't start print "could not activate z"
I go to print a calibration cube on my tevo tarantula and after the bed and extruder are heated, everything is homed and is about to start I get the message "could not activate z" and it stops, please help
Could not activate z-probe offset due to coordinate constraints - result is inaccurate!
In that case you need a homing order with preheat (which can be set to 0). Then you can set homing position for z such that z probe can be activated and then it will also probe Z.
