want to use old electronics
Hi
I have a set of old boards i want to use, from what i know they are a sanguino hack where some of the pins/functions have switched place and support for an extra set of steppers was added so it could run a max of 3 extruders... along with that also 2 extra heaters could be used...
i do have a set of arduino IDE board definition files for it (ide 0022) how should/would i use this board in the config tool before i download the firmware?
can a 644P based board be used at all?
