About the command "M3/M4/M5"
I am new to Repetier. These days, I am trying to build my own machine. During reading the firmware, I found that " Other tools may use M3 and M5 to enable/disable laser". I check the firmware, however, I did not find them (the detailed coding).
So, could someone give me a help? Thanks.
- M450 - Reports printer mode
- M451 - Set printer mode to FFF
- M452 - Set printer mode to laser
- M453 - Set printer mode to CNC
And if you have support compiled in these commands have an effect as compiled into driver (default is only on/off). For laser - it will only enable if you increase E or on P1 moves with M3 enabled.
What do you mean "For laser - it will only enable if you increase E or on P1 moves with M3 enabled" ? Could you explain it please? Thank you.
