Filament change mid print not working
I want to change a filament at a particular layer (colour change) when I insert M600 into the g code at the layer I want to change the filament, nothing happens. It prints as if nothing has happened. Is there something better have to activate?
If you print using repetier-server or host you can simply add a
;@pause Message
where you want to pause. The server/host will go into pause mode at that position.
check your configuration.h for if Feature Retraction is enabled
#define FEATURE_RETRACTION 1
if this doesn´t fix it try
M24 to pause / M25 to continueDo I need to 'Enable G10/G11 retraction and filament change and allow jam detection' in the config tool.
It seems to have settings for filament change i.e homing, X Y head positions etc, but the G10/11: "This feature allows slicers to use the commands G10 and G11 for retracting and undo retracts instead of adding the moves on their own. These parameters can be changed in EEPROM later. Autoretraction converts pure E moves into G10/G11. For that reason it is when enabled not possible to extrude with only E axis. So if you want to use it, I would suggest to enable/disable it with M209 S1 and M209 S0 in the slicers start and end g-code so it is normally disabled. So i wasn't keen on activating this????
Thanks again for your reply
I´m not familiar with the use of G10/G11
just went through the code and saw that M600 Needs Feature retraction and UIcontroller to get active
I want to put the layer on my LCD screen. With M117 however it only briefly flashes on is there a way to keep it permanently on the screen for prints where the filament to be changed so I can monitor via web cam.
M600 Load Blue Filament
In theory, this would update the "status" (after the Filament Change menu is displayed) to "Load Blue Filament"...
I'll update the post, if the change (hack) works!
With this change, one can pass "comments" as described above.
The only caveat, is the "comment" remains when you exit from the Filament Change menu...
You can, of course, follow your M600 with an M117 to set a new (or blank) comment in the status line.
I've checked the voltage on the D5 pin (+5VDC when no filament passes through sensor, 0VDC with filament).
I've got:
#define EXT0_JAM_PIN 5
#define JAM_METHOD 2
#define JAM_ACTION 1
If I issue G1 E1 (with or without filament), nothing changes
M603 correctly simulates filament out...
Any thoughts what I'm doing wrong for filament out detection while printing (G1 E1)?
so next signal triggers. So maybe you need the same. I have this at various places e.g. continue print script in server set. Also jam control must be enabled
M602 P0
should enable it.
