Autobedlevel and Z_PROBE_HEIGHT
PmKPmK
edited December 2017 in Extruder & Bed
Ive moved to repetier and now i want to enable autobedleveling.
I have an inductive sensor which is 1.15mm above the nozzle-tip and i have a max-sensor too.
I start homing to the max-sensor and when i then do a G29 the head is running down and tries to sense the bed but its doing that on 1.15mm where my inductive sensor already triggers.. and then it fails because of no signal change on the pin.
What am i doing wrong?
 #define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 5
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 40
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 1
#define Z_PROBE_XY_SPEED 30
#define Z_PROBE_SWITCHING_DISTANCE 5
#define Z_PROBE_REPETITIONS 1 //WORKS
#define Z_PROBE_HEIGHT 0.95
#define Z_PROBE_HEIGHT 1.15
#define Z_PROBE_REQUIRES_HEATING 1
#define FEATURE_AUTOLEVEL 0
#define Z_PROBE_X1 60
#define Z_PROBE_Y1 60
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 40
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define ENDSTOP_Z_MAX_INVERTING true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_Z_BACK_ON_HOME 1 #
define ALWAYS_CHECK_ENDSTOPS 1
  • First: Autoleveing command is G32 S2 (S2 to store result in eeprom)
    Second: Check eeprom if distances are also there correct
    Z_PROBE_BED_DISTANCE is the start height of nozzle for probing. If your z length is set too high it will test lower, so I guess yu have to reduce z length in eeprom editor.
  • Ive disabled the eeprom because i cant get the values out there and i want to get sure that i have a valid copy of the printer-setup. I only use the setup posted above.
    #define X_MAX_LENGTH 220
    #define Y_MAX_LENGTH 220
    #define Z_MAX_LENGTH 250 <- you mean this value?
  • Another quick question, do i need to define the minimum endstop when using this input as a zprobe?
  • Ok.. Ive found out that z_max_lenght was the problem. Thank for the help.
    My biggest problem is, that i cant go below the triggerpoint of the probe but i need to keep it higher then the nozzle.
    I could disable always_check_endstops but that will give me more trouble then it helps me..
  • Make sure you have not set z probe also as z min endstop. In fact do not add a z min endstop at all. These are different especially with z max homing. With z min homing they must be identical.
