G31 state H
in Bug Reports
Hi all,
Repetier version 92.3
a Normally Open switch connected on Z-MIN pin
and 3 -MAX endstop for a DELTA.
here is my settings:
#define ENDSTOP_X_MAX_INVERTING true
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_Z_MAX_INVERTING true
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 25
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 80
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 80
#define Z_PROBE_X2 -80
#define Z_PROBE_Y2 80
#define Z_PROBE_X3 80
#define Z_PROBE_Y3 80
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
When i check with G31 the state returned is RANDOMLY High or Low even if the switch is trigger or not.
What is wrong ?
What is wrong ?
how Printer::isZProbeHit() working ? where is the piece of code that test the pin state ?
i play with pullup state connection pin and now works great.
