Need to slowly heat up the bed not to break the glass - is it possible?
Hi, all.
I am going to install the silicone heater pad 220v 200w on my prusa 200x200 mm bed. It will be powered via SSR. I am going to use dead time control. But am afraid that it will heat up way too quick and the glass on the bed will break. Is it possible to set up the speed of heating in the firmware? I need a compromise: not as slow as the original 12v heater but not as quick as the 220v silicone heater pad is capable if turned on 100% at the beginning of heating.
If such a set up is not possible which workaround would you consider?
Thank you.
Thank you.
