Move buttons send absolute coordinates
When I press the Repetier Server web interface button to move the X axis 10mm in the positive, Repetier Server sends the command:
That sends the extruder to exactly X10. Further button presses send the same command. If the Extruder is already at X10, it doesn't move. I expect these buttons to send relative motion commands. I expect each button press of +X10 to move the X axis 10mm to the right.
This behaviour was correct once. I don't know what could have changed. How I can get the correct behaviour from this button? All axes, including E, observe this behavior. When I extrude 10mm, it sets the position of E to 10 and I can't extrude more with another button press of E+10. I see the position with M114.
The desired behaviour is observed with Printerface/Printrun over USB with my Macbook. I don't think this is a printer problem.
N90 G1 X10.00 F300000
If I set printer to relative coordinates it just always sends 10, but head moves:
So if server always sends X10 it thinks printer is in relative mode while it is in absolute mode. Please try sending G90 to convince it that it is in absolute mode. Question is of course still why would server think that. Did you switch outside server so he did not know?
