hole diameter dimension
hi thank you for everythign i have a problem i design a disc inside hole diameter dimension is 10mm but i printed 9,5mm how can solve that?
  • That is more a slicer thing/design, but dragging filament inside on holes is a known problem. Also you design it as circle it gets exported as faceted triangles shrinking the effective diameter a bit. So normally you design holes a bit bigger then needed so after print it matches better.
