bed pid tune strange
so i wanted to do a pid tune of the bed just to be sure
M303 P1 S100
it goes to 100 with no issue, i get
13:12:55.466 : Info:PID Autotune start
13:15:28.608 : bias: 170 d: 84 min: 99.01 max: 100.89
13:16:11.591 : bias: 235 d: 19 min: 99.01 max: 100.78
but the temp climbs to 108 and in the end i get a timeout
what could be the reason for this? the firmware can see that the temp is above 100 but yet it keeps heating (led flash very fast)
  • The autotune uses a mathematical algorithm to test swinging behaviour. It sets pwm to bias +/- d. After your last test this means it wants cooling with 235-19 = 216 pwm setting which seems enough to heat further. So the algorithm was diverging too much for your wanted target temperature.
    You could test with 90°C and see if it does converge in that case. Guess the algorithm has some limitations on what it can work with.
  • oki... wil try and figure what the highest temp it can do
    are there any "hidden" parameters i can change to go higher?
  • hmm... i think my thermistor is bad again
    replaced it 2 months ago
    i tried 90 and temp was hovering at arround 65
    60 still works
