No support in Repetier, only moves
Hi all,
I have problem a little bit similar like http://forum.repetier.com/discussion/3786/invisible-object-after-slicing
G-code flavour I think is correct, RepRap (Marlin/Sprinter), G-code after slice look OK in slic3r, in green color. This generated G-code after opening in Repetier-Host look like without supports, only moves. What can be wrong?
