lower Z below zero?
Hello,
in my current Setup i'm using a contactless Endstop for Z_min. Is there any possibility that I can preconfigure the printer to lower the Z-axis below zero after homing? It works in positive direction using ENDSTOP_Z_BACK_ON_HOME, but using negative values does not affect the printers behaviour.
I'm using Repetier 1.0 dev.
thank you for your help!
Changing Extruder Offsets (EXT0_Z_OFFSET) works but is not available in the config tool. You can change the values in the EEPROM with Repetier Server or Host or in the code. Be aware that the unit is [steps], so if you want to enter an offset in mm you have to consider ZAXIS_STEPS_PER_MM.
"zOffset": 0,
or
"zOffsetSteps": 0, in the config string?
Is there a complete "translation" of firmware parameter names to config string names? This would be very useful sometimes
