Heated bed issues with Repetier Firmware and Mendel
Hello!!! After conducting PID test for heated bed(Repetier-Firmware) MatterControl gave me an error (#91 if I remember right) and my bed stopped working. I checked voltage on terminal and got 0. After jumping around with a drum I installed Mendel-Firmware and bed was operable with (12 V) on terminal. I have tried to reinstall Repetier-firmware with different heated bed settings but still cannot get current on HB terminal.
If you encountered similar problem please share your thoughts. Thank you.
Why do you need to change pins on a new firmware upload? Also that should not change anything. A normal reset would also restart firmware. Could it be a fuse resetting so output stops? I know that RAMPS bed fuse is quite tight designed for some beds. Not sure what melzi uses here.
