Where to see third temp sensor value?
Hi, everyone.
I have connected to the motherboard third temperature sensor. It should show the temperature inside the printer enclosure. Where can I see it's value (temperature)? I would be equally satisfied to read this temperature in Host or on the LCD. The board I use is MKS Gen-2Z v1.1. There are three inputs for temp sensors: E0, Bed, E1. Temp sensor for enclosure is connected to the E1 input. It is set in the firmware (v.1.0 dev). I use only one extruder. Does anyone have experience with third temp sensor?
Thank you for idea. Little problem is MKS Gen-2Z has only one socket for extruder driver (totally 5 sockets, for X, Y, Z1, Z2, Extruder0; where Z2 stepper is connected to E1 socket). If in setup wizard I enable Extruder 2 I should assign "extruder stepper" to it. If I assign "Extruder 2" than compilation is not possible because ORIG_E2_STEP_PIN, ORIG_E2_DIR_PIN and ORIG_E2_ENABLE_PIN are not defined in pins.h
If defining those pins is the right way to go, which pins can I assign not to burn the board?
If I don't define second extruder (E1) data from corresponding third temp sensor could not be read.
If there is other way I would be glad to know. Thank you in advance. And thank you for great software and great support.
